MrSmoofy
Mar 15, 2016Aspirant
Which WiFi range extender should I buy?
My situation is I live in an Apartment. I haver Verizon FiOS 150/150. The location of the Verizon FiOS router is located in the living room. The room I want to use as my office space is conside...
DarrenM
Mar 16, 2016Sr. NETGEAR Moderator
Hello Mrsmoofy
Since you said you want the max speed and you need ports have you looked into powerline adapters they can carry the full speeds across your powerlines. There are some drawbacks such as if you are in a place with old wiring.
DarrenM
