MrSmoofy
Mar 15, 2016Aspirant
Which WiFi range extender should I buy?
My situation is I live in an Apartment. I haver Verizon FiOS 150/150. The location of the Verizon FiOS router is located in the living room. The room I want to use as my office space is conside...
DarrenM
Mar 16, 2016Sr. NETGEAR Moderator
Hello Mrsmoofy
Since you said you want the max speed and you need ports have you looked into powerline adapters they can carry the full speeds across your powerlines. There are some drawbacks such as if you are in a place with old wiring.
DarrenM
MrSmoofy
Mar 16, 2016Aspirant
I can get gigabit speeds across power lines? I'm not sure of the age of the wiring so that could pose some issues but that is an interesting idea I've always shyed away from using the power line adapters because I've heard so many people have issue with them working.
- DarrenMMar 16, 2016Sr. NETGEAR Moderator
Yes we do offer models that have gigabit ethernet and yes this does not always work for everyone it just all depends on the house electrical setup.
http://kb.netgear.com/app/answers/detail/a_id/20233
DarrenM
