MrSmoofy
Mar 15, 2016Aspirant
Which WiFi range extender should I buy?
My situation is I live in an Apartment. I haver Verizon FiOS 150/150. The location of the Verizon FiOS router is located in the living room. The room I want to use as my office space is conside...
AlvaroIsaac
Mar 19, 2016Guide
You should stay away from powerline networking, not because it isn't effective; but because you live in an apartment and you are more likely to get a high amount of signal interference from all the shared electrical wiring.
In my experience, you can get more than enough speed with the EX6200 in bridge mode. Essentially, it uses all its Wifi power to give you near wired speeds in your office. Alternatively, I have used Fastlane-tech to have a completely wireless setup in a similar office situation. You are still basically limited only by your ISPs bandwidth and not your home network speed.
