RandomAcc
Apr 30, 2024Tutor
Why is my router not allowing sites?
In short, I can't access the Steam app, Vortex app, or even go to mywifiext,net becuz it says I have no internet but I clearly do since other sites and apps work. I never had these issues until I sta...
May 01, 2024Guru - Experienced User
We need a few more details.
1. what router do you have?
2. are you using an extender? you posted in the extender forum and the mywifiext is for extenders. If so, what extender?
3. What firmware is on the extender?
4. Firmware on router?
5. Is it the connection to the extender having issues or the router?
RandomAcc
May 02, 2024Tutor
I think its an extender? My roommate gave it to me when I moved my pc into my room from the living room cuz the wifi didnt connect, it says AC750 Wifi Range Extender Model EX3110 on the back. It's just like a cube thing. I don't know what firmware is, but I can try to find out.
- plemansMay 03, 2024Guru - Experienced User
EX3110 is an extender.
what router is it connected to?
Did you set it up using wps or using the installation assistant?
If WPS, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk- RandomAccMay 06, 2024Tutor
That is how I originally set it up, and we have a cox router. I'm thinking of buying a brand new extender next time I get paid cuz this one is giving me more trouble than it's worth at this point.
- plemansMay 07, 2024Guru - Experienced User
If you're looking for a new extender, I'd look at the tri-band versions. they have a dedicated backhaul and this makes them much faster and with lower latency.
