Stuey7
May 15, 2020Tutor
Wi-Fi Extender EX2700 / N300
Good morning The extender was working fine with no problems. Then my eldest daughter connected to it and it started to create an issue with my connected device. I thought if i factory reset the e...
Stuey7
May 15, 2020Tutor
Thank you for replying
I am a total novice when it comes to stuff like this. Very surprised to get it running in the first place. Will your solution help with connecting the extender to the router??
The Ext is visable in my phone wifi settings but requires login/authorise to access, trying to login brings up a blank page with no other options. Apologies as to you it may seem very straight forward.
May 15, 2020Guru - Experienced User
Stuey7 wrote:Thank you for replying
I am a total novice when it comes to stuff like this. Very surprised to get it running in the first place. Will your solution help with connecting the extender to the router?? Potentially. Can't say 100%
The Ext is visable in my phone wifi settings but requires login/authorise to access, trying to login brings up a blank page with no other options. Apologies as to you it may seem very straight forward. That's why I prefer to hardwire into extenders for setup. If you have a pc/laptop around you can run setup on it via the ethernet connection. Then you're not relying on wireless or having to connect/reconnect during setup. If you have the option, its worth doing this route.
what router are you connecting it to?
- Stuey7May 15, 2020Tutor
I can take my work laptop home to try it.
Initial set up it connected absolutely no problem. I cant even load up the new extender page on anything to try.
So if i hard wire my laptop to the extender, even though it hasnt connected to the router that will work??
It is a Virgin V6 hub the router
- plemansMay 15, 2020Guru - Experienced User
You can try setting it up that way. It might have more luck.
I'd try the hardwired version. Especially on a different pc. Or even try a different browser on the one you're using.
but your issue also might be with the virgin hub v6. Some isp's have been pushing their own extenders. And I've found some of them don't play nice with 3rd party extenders because the isp's want to make more $ charging for their own extenders.
Not saying its the case but if nothing works during setup, its worth checking into.
Thank you
I appreciate your advice very much. I will give it a go tonight/tomorrow, do not be surprised to see my cries for help on here next week though.
