Stuey7
May 15, 2020Tutor
Wi-Fi Extender EX2700 / N300
Good morning The extender was working fine with no problems. Then my eldest daughter connected to it and it started to create an issue with my connected device. I thought if i factory reset the e...
May 15, 2020Guru - Experienced User
You can try setting it up that way. It might have more luck.
I'd try the hardwired version. Especially on a different pc. Or even try a different browser on the one you're using.
but your issue also might be with the virgin hub v6. Some isp's have been pushing their own extenders. And I've found some of them don't play nice with 3rd party extenders because the isp's want to make more $ charging for their own extenders.
Not saying its the case but if nothing works during setup, its worth checking into.
Stuey7
May 15, 2020Tutor
Thank you
I appreciate your advice very much. I will give it a go tonight/tomorrow, do not be surprised to see my cries for help on here next week though.
