stormann59
Feb 26, 2020Aspirant
wi fi extender frontier model no. ex6100
I have two different netgear products that I am supposelby able to use if linked by ethernet cable. My router/modem is a nighthawk 7000 cv2 and my extender is my old frontier ex6100. Any help would b...
Feb 26, 2020Guru - Experienced User
not sure why say "old frontier ex6100"? maybe it was connected to your frontier setup?
If its a netgear EX6100, it should connect to the C7000v2 (if thats what you have?) fine.
If you're hardwiring it into the c7000, it'll run in access point mode.
I would recommend factory resetting the EX6100 before setting it up.
stormann59
Thanks will try reset It originally was purchased through frontier when I was using them. When activated it still shows frontier which of course is no longer supported.
- plemansFeb 27, 2020Guru - Experienced User
I didn't know frontier sold their branded extenders.
What firmware is on it? (firmware number)
- stormann59Feb 27, 2020Aspirant
They do not sell their own I just meant it came from frontier originally, I did the reset and it is working thank you for your assistance.
