tl113
Nov 28, 2020Guide
wi fi extender stopped working
My wifi extender EX8000 – AC3000 Nighthawk X6S Tri Band WiFi Range Extender stopped working and will not connect to the router anymore. I have even tried to reset it. It keeps sayong ahving issues c...
Reghar
Dec 06, 2020Aspirant
I had similar issues resetting the extender. Make sure its powered on when resetting hold down for 10 seconds until it flashes Amber. Then Try this after when you get the connection to devices issue....
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/Nighthawk-Password-incorrect-Solution-finally/td-p/2017862
