tl113
Nov 28, 2020Guide
wi fi extender stopped working
My wifi extender EX8000 – AC3000 Nighthawk X6S Tri Band WiFi Range Extender stopped working and will not connect to the router anymore. I have even tried to reset it. It keeps sayong ahving issues c...
tl113
Dec 08, 2020Guide
Firmware 1.0.1.224 latest version available at updated fine. it still keeps saying trouble connecting to my network telling me to reset my router I keep doing that and it still will not connect. when I try to do the test my speed it keeps giving me an error that I cannot connect. When I did the hard factory reset and then I reconnected everything I just did it through the app on my phone and I had download speeds of 134 and now I cannot connect again at least when I try to test my speed or do any kind of analytics
Dec 08, 2020Guru - Experienced User
What router are you connecting it to?
Did you use wps or the installation assistant?
I'd highly recommend the installation assistant.
