Eccleslad
Feb 07, 2020Aspirant
Wi-Fi Mesh connections
I want to buy a Netgear Wi-Fi mesh system for use in a two storey, steel frame, concrete floor building about 60ft square. Internal walls are brick. It is a non-domestic building. Our phone/ broadba...
- Feb 13, 2020
Eccleslad wrote:Thanks for your response. Two further questions from a non-techy.
1. Would there be any signal strength loss due to long ethernet cable connection? Due to satisfactory routing of the cables, cable length could be 20m.---thats fine. You can run up to 100m with proper ethernet cables.
2. The building in question has occasional public usage.. I was thinking about positioning the units above a grid suspended ceiling out of reach of tamperers. Is a separate power supply necessary or does ethernet cable provide power?-----the consumer orbi and most of the pro orbi's don't support power over ethernet. They need their own power supply There is 1 satellite in the pro version that does. its the SRC60.
Eccleslad
Feb 13, 2020Aspirant
Feb 13, 2020Guru - Experienced User
