Meady23
Oct 19, 2019Guide
Wi Fi Range Extender Password Help
Hi All. My friend took my Range extender to try one before he bought one at his house. I now have it back and am trying set up again for my network. I done a factory reset, linked to my router and...
- Oct 19, 2019
Make sure to factory reset with it powered up. Push and hold the reset button until the lights change. so do it like this:
plug it in and turn it on. Give it a couple minutes to fully boot. Push and hold reset. Its usually 7-10 seconds but hold the reset button until the lights on the front change. that should make sure its factory reset. I just want to make sure you do it right as I've seen/read about people just hitting the reset button for a short period and think that resets it.
Oct 19, 2019Guru - Experienced User
Meady23 wrote:Thanks for advice. I have tried hardwiring to router and just hardwired to computer. I get the two extensions on my iphone avalible but the correct password for internet router keeps saying it is incorrect on 2.4 and 5ghz
Just hardwire it to the computer. It should only be asking your for the administration login info and not the wifi passwrod if you're hardwired in. Once you've logged into it, you can change the wifi settings.
Meady23
Oct 19, 2019Guide
Thank You, I did get to this step since posting. I really appreciate your help. I am up to the password step. What should I enter here?
I had this extender working for years just have had to re setup so have no details on password info that come with it.
- plemansOct 19, 2019Guru - Experienced User
the default login is admin. default password is password.
If you've changed it, then you'll need to factory reset.
- Meady23Oct 19, 2019Guide
Thank You, I have done a factory reset and no luck with the admin and password combo. I don't normally have too much trouble with these installs. Frustating.
