Meady23
Oct 19, 2019Guide
Wi Fi Range Extender Password Help
Hi All. My friend took my Range extender to try one before he bought one at his house. I now have it back and am trying set up again for my network. I done a factory reset, linked to my router and...
- Oct 19, 2019
Make sure to factory reset with it powered up. Push and hold the reset button until the lights change. so do it like this:
plug it in and turn it on. Give it a couple minutes to fully boot. Push and hold reset. Its usually 7-10 seconds but hold the reset button until the lights on the front change. that should make sure its factory reset. I just want to make sure you do it right as I've seen/read about people just hitting the reset button for a short period and think that resets it.
Meady23
Oct 19, 2019Guide
Thank You, I have done a factory reset and no luck with the admin and password combo. I don't normally have too much trouble with these installs. Frustating.
Oct 19, 2019Guru - Experienced User
