TXBreck
Dec 20, 2011Aspirant
Wife pressed the WPS button
My wife thought there was a connection problem with here laptop even though she is hardwired to the router. She pressed the WPS button and now all of our wifi connections do not work. It asks for a ...
jmizoguchi
Dec 20, 2011Virtuoso
you need to use pc wired the router and access the router :)
you can NOT use wifi to access router interface if you can NOT connect wirelessly.
login the router and try to check your wireless setting again.
manual can download at support.netgear.com
