RoxieChurch
Apr 18, 2019Aspirant
Wifi Booster Requires Password?
I recently purchased this Wifi Range Extender, it works great....but only when the product it is trying to connect to supports WPS connection, for some reason ever since I updated router (its still a...
schumaku
Apr 18, 2019Guru - Experienced User
WPS does "magically" bring the primary router wireless password to the exender in a light secured way. That's the one you use for connecting manually to the router and the extender.
RoxieChurch
Apr 20, 2019Aspirant
Will I need to redo my Booster set up to find a password then?
- Christian_RApr 25, 2019NETGEAR Employee Retired
Hi RoxieChurch,
Thanks for your post. Yes, you can factory resetting the extender and going through the setup instructions again.
~Christian
