BryanP
Feb 24, 2018Aspirant
Wifi entender with baby monitor
Hello,
I am not a tech savy guy and ned some advice on what to buy. Our wifi doesnt reach our babys room and I am looking at wifi extenders. My question is will this option work for video/sound etc being sent back to the main network or will it be on a seperate network and I wont get the info sent back to me? I am not sure if this is a one way signal option or two way...if this makes any since. Very much appreciate any advice. Thank you!
Hello BryanP
The extender would create a seperate wireless network but it would still be on the same network as the router it is connected to.
DarrenM
- jvasanth1984Virtuoso
Hi BryanP,
All extenders are pass through device where it your baby monitor works with your Router's network, it'll work via extender too.
- BryanPAspirant
So I dont need to worry about the extender having a seperate IP (or something...not sure) that it wont communicate back to the main network IP? Thanks so much for your help!
- DarrenMSr. NETGEAR Moderator
Hello BryanP
DarrenM
