ExtenderDon
Aug 24, 2024Tutor
Wifi Ex5000 setup
It appears that Netgear does not support this extender from what I see on their website. I have reset mine and tried everything to reestablish communication to it: i.e mywifiext, IP address etc. Usin...
- Sep 01, 2024
Thanks for the help - Found the WPS button on the router and got the extender connected.
Thanks again to you and the others who responded to me.
Aug 31, 2024Guru - Experienced User
have you used wps?
ExtenderDon
Sep 01, 2024Tutor
MY router does not have a WPS button.
Thanks for the comment.
- plemansSep 01, 2024Guru - Experienced User
What router do you have?
- ExtenderDonSep 01, 2024Tutor
Xfinity
that's your ISP. Not your modem/router
