cylon
Feb 06, 2020Tutor
WIFI extended - who is connected?
How can i figure out who is connectedto my wifi extended? I know who is connected to my router but not the extender, thanks
cylon
Feb 06, 2020Tutor
thanks - it dosent work with Firefox, had to switch to Edge, now I see them, thanks again
Feb 06, 2020Guru - Experienced User
If you mark it as solved it helps the next person find the the answer faster as well as it helps prevent others from trying to fix the issue when its already been solved. :)
Enjoy!
