leaserlakeguy's avatar
Sep 09, 2015
WiFi Extender - College Dorm
My daughter has a poor wifi signal in her college dorm room.  To set up an extender do we need to have access to the router, or can we just plug it into an outlet and improve the signal?
    • leaserlakeguy's avatar
      leaserlakeguy
      OK, thanks...  Any suggestions if we can't get direct access to the router?
      • nhann's avatar
        nhann
        NETGEAR Employee Retired
        You won't need physical access to the router.
        The setup for the extender would require that it be in range of the router, so that it can extend to the room you would like.
