gaschneck
Feb 07, 2020Aspirant
WiFi Extender - Nighthawk X6 R8000
I have a Nighthawk X6 R8000 router in a closet on the second floor of my house. Near the back middle section and the signal drops occasionally when a laptop is used in the kitchen, back of the house...
Feb 07, 2020Guru - Experienced User
How large (sq ft) is your home?
what materials is your home made off?
many times, optimizing your router location can help more than adding in extenders.
things like optimizing channel, centrally locating the router, making sure things aren't blocking signals all can help. HVAC in walls/ceilings is great at blocking wifi signals. Sometimes moving the router to a different room/area can help immensely.
Reason why extenders aren't always that great is that extenders have their benefit but they also have downfalls. standard extenders will slow the speed and increase the latency coming from your extenders because they have to receive and re-transmit signals. Tri-band extenders help mitigate that by reserving a single band for just router----extender communication.
- gaschneckFeb 10, 2020Aspirant
Thank you for your reply. House is a stucco house that is very well insulated with foam. Bottom floor is block and second floor is wood. 4200 sq feet. Router is in a central location on the second floor. My office is almost directly below the router and there are very few issues with the WiFi dropping. It is the kitchen area which is further away that the problem happens. I am thinking an extender may help.
- plemansFeb 10, 2020Guru - Experienced User
Sounds like a good plan. If your interior walls are wood/sheetrock an extender will probably work great. And 4200 sq ft should work perfect with an extender and the R8000. I'd recommend one of the tri-band extenders to complement the R8000. I've got the EX8000 and it works great. Never used it with something like the R8000 though.
Thanks for the info!
