TonyGasson
May 02, 2025Initiate
Wifi Extender 6120
Hi, I have just changed router and while I have successfully paired the Extender 6120 to the router my devices cannot access the Extender as the new router password is not recognized by the Extender....
TonyGasson
Thank you Michael. I got into the extender with the IP address as you suggested and the 5ghz extension is now connecting to my devices with a new password but for some reason the 2 ghz appears switched off. Any further suggestions? Thank you again
May 02, 2025Guru - Experienced User
got a copy of what the status page shows?
Did you setup the 2.4ghz connection?
Are you using fastlane?
