TonyGasson
May 02, 2025Initiate
Wifi Extender 6120
Hi, I have just changed router and while I have successfully paired the Extender 6120 to the router my devices cannot access the Extender as the new router password is not recognized by the Extender....
TonyGasson
Thank you Michael. I got into the extender with the IP address as you suggested and the 5ghz extension is now connecting to my devices with a new password but for some reason the 2 ghz appears switched off. Any further suggestions? Thank you again
michaelkenward
May 04, 2025Guru - Experienced User
TonyGasson wrote:
....5ghz extension is now connecting to my devices
Remember, the extender does not connect to your devices. It is the other way round.
Devices connect to the router.
They decide which channels to use. They'll go for 5 GHz to get the speed, falling back to 2.4 GHz if they are too far from the router.
Disclaimer: Just another user with time on their hands.
