jeffk33's avatar
jeffk33
Follower
Jun 23, 2020
WiFi Extender AC1200 EX6150
Hey, I have a problem trying to connect to my wifi extender. I connected it with WPS and it worked however when I try to connect it with my other devices the wifi extender isn't popping up on my wifi icon to connect. I've tried to do this multiple times and no wifi extenders are popping up on my wifi icon list.
1 Reply
  • plemans's avatar
    What router are you connected to?
    Try resetting it back to factory and installing it using the smart installation wizard. Not all device makers code wps the same and it can cause issues.
