bdagle
Apr 21, 2023Aspirant
wifi extender ac1200 MODEL WFR-02
I can't find how to set up my model after it became disconnected
Apr 21, 2023Guru - Experienced User
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with for install guides.
You can also use the installation assistant.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
