Trafford1
Jun 07, 2020Tutor
WiFi extender AC1200
Hi when I’m trying to connect my Xbox one to my WiFi extender the device light goes a solid green then goes again and on my Xbox it says it can’t connect can anyone help
- Jun 09, 2020
glad to hear you got it working with the assistant!
If you mark it solved, it can potentially help others with this issue in the future.
Trafford1
Jun 09, 2020Tutor
It’s an ac1200 extender and I’m connected to a technicolour WiFi and yeah all devices are having the same issue I even factory reset it and tried again and when I put the correct password in the device light goes green and then goes off again after a second and says I have put the incorrect password on
Jun 09, 2020Guru - Experienced User
Trafford1 wrote:
It’s an ac1200 extender-----Not a model. See above. and I’m connected to a technicolour WiFi ----also not a model. and yeah all devices are having the same issue I even factory reset it and tried again and when I put the correct password in the device light goes green and then goes off again after a second and says I have put the incorrect password on
Please add the models.
Did you setup the extender using wps or the installation wizard.
- Trafford1Jun 09, 2020TutorSorry I’m currently out at the minute so not sure what models and I set it up through wps and by the looks of it many people have the same issue
- plemansJun 09, 2020Guru - Experienced User
when you get back, factory reset the extender and reinstall using the installation wizard.
device makers code wps differently between manufacturers. When that happens, you use the install wizard.
- Trafford1Jun 09, 2020TutorManaged to get it working via the installation assistance wizard thanks
