unusedname13's avatar
unusedname13
Follower
Jul 02, 2023
Wifi extender AC750
I have a wifi router that only has 5.0G  Can I use the AC750 to extend the 5G network and create a 2.4G network?
1 Reply
  • schumaku's avatar
    schumaku
    AC750 might indicate some kind of speed, but not a unique device model.
    When looking into https://www.netgear.com/support/  and enter AC750, there are a bunch of models showing "dual band", and a few newer models like the EX3920 support 2.4 and 5 GHz as Dual Band, too.
    Check your AC750 extender product label FMI.
