Ckils24
Nov 04, 2019Tutor
WiFi extender ask for security key. My WiFi security key won’t work.
- Nov 05, 2019It worked. Thanks. The network security key was different on my extender than my router, so using the firmware allowed me to go through the setup and change it to my router security key.
Ckils24
Nov 05, 2019Tutor
I haven’t been able to connect my device to the extender to setup the connection through a web browser. The WPS way doesn’t work either. If I connect the Ethernet to from my laptop to the extender will I be prompted? In the booklet it doesn’t give a way to hardwire connect from the extender to a device. Thanks for letting me know.
Nov 05, 2019Guru - Experienced User
When you've hardwired in, just follow the same install procedure as you would normally. Go to mywifiext.net and it should allow you to connect with the extender for setup, firmware updates, etc.
- Ckils24Nov 05, 2019TutorIt worked. Thanks. The network security key was different on my extender than my router, so using the firmware allowed me to go through the setup and change it to my router security key.
