Ckils24
Nov 04, 2019Tutor
WiFi extender ask for security key. My WiFi security key won’t work.
- Nov 05, 2019It worked. Thanks. The network security key was different on my extender than my router, so using the firmware allowed me to go through the setup and change it to my router security key.
Nov 05, 2019Guru - Experienced User
When you've hardwired in, just follow the same install procedure as you would normally. Go to mywifiext.net and it should allow you to connect with the extender for setup, firmware updates, etc.
Ckils24
Nov 05, 2019Tutor
