carlos181
Nov 29, 2020Follower
WiFi Extender EAX20:
I'm pretty certain that I could successfully install the extender (Model EAX20-100NAS) because I followed the steps in the Nighthawk App and they worked as expected. My question is "How do I know tha...
- Nov 29, 2020
Its a mesh extender when installed using wps or using the default install settings. Meaning it uses the same ssid as the router. (same name)
You can log into the extender and see what devices are connected to it.
Once its setup, you should be able to move it where you want it without having to reinstall
Nov 29, 2020Guru - Experienced User
