Pier_Paolo
Feb 29, 2020Star
WiFi extender EX3110
Buongiorno a tutti. Ho un Wi-Fi extender modello EX3110. Ho configurato entrambe le bande, sia quella da 2,4 che da 5. Quando esco di casa lo spengo e qualche volta capita che la mia PlayStation, col...
- Mar 01, 2020Update: it worked!!
I updated the firmware and also I did the reset by WPS and now I see that also 5Ghz is working. So that was the key. Thanks again for your support!
Feb 29, 2020Guru - Experienced User
Is there a reason you're shutting it off? Why not leave it running?
are you using fastlane for setup?
How far from the router is the extender? 2.4ghz broadcasts much further and through more material than 5ghz but has significantly less throughput. If you're far enough away that the 5ghz isn't reaching, when the 2.4ghz does connect, its going to have a slower speed.
Have you tried factory resetting and re-installing?
I'd also update your firmware. Your screen shot shows you on v1.0.0.44 which is 5 versions out of date. the newest is 1.0.1.62.
so try updating the firmware as well.
Pier_Paolo
Mar 01, 2020Star
Update: it worked!!
