RobbyD
Jul 30, 2021Follower
Wifi extender EX3700 keeps dropping 2G at around 2AM and cannot reconnect
Hi, hope someone can help or has heard of something similar. My Wifi extender EX3700, I use only for the Ring security cam at the back of the house, with the Sky router at the front of house. The...
Jul 30, 2021Guru - Experienced User
Did you set it up using wps?
have you tried setting it up using fastlane? (so it dedicates the 5ghz for backhaul)
