Memnochthedevil
Aug 01, 2022Aspirant
WIFI extender (EX6100) won't connect to router
Hello everyone! So my extender was working fine for a few months but yesterday I was having some issues, reset it and now the wifi light isn't turning on, when I try to set it back up "NETGEAR_EXT" ne...
- Aug 01, 2022
So your leds are showing its powered on and a device is connected to it. just not a router.
Try hardwiring a pc/laptop into the extender and logging into the extender. From there you should be able to re-run setup on the extender.
Just make sure that the pc/laptop you connect to it doesn't have the wifi on or it can default to the wifi connection
Aug 01, 2022Guru - Experienced User
