bpic67
Apr 26, 2021Tutor
WIFI extender EX6110 - Connecté - aucune connexion internet
Bonjour, J'ai changé de BOX pour passer à la Fibre. J'ai fait un reset de l'extender, connecter l'externder à la nouvelle box en WPS Quand je me connecte au réseau 2GEXT ou 5GEXT, il me demandait d...
Apr 26, 2021Guru - Experienced User
Try reinstalling the extender but use the installation assistant and NOT wps.
- bpic67Apr 27, 2021Tutor
Hello i did th installation site the web site and at the end, i get the message
you are not connectée to Your extender wifi network .
all the lights are Green
- plemansApr 28, 2021Guru - Experienced User
Log into your router.
see if the extender is showing as an attached device.
If it is, you can use the ip address to log into it.
