JayschInitiateFeb 08, 2022WiFi extender ex6110My WiFi extender won't accept my new routes password,how do I get it to accept the new password?
plemansGuru - Experienced UserFeb 08, 2022What router are you connecting it to? What method of setup did you use? WPS?
plemansGuru - Experienced User to JayschFeb 08, 2022what vodafone router? (some are pretty sketchy) Try setting up the extender using the installation assistant. So factory reset the extender and then use the installation assistant.
