dthedeejay
Jul 23, 2019Aspirant
WiFi Extender EX7000 - Failed Update
Just did a firmware update using the web interface and extender not working anymore. Cannot connect to extender with http://mywifiext Tried holding factory reset button for more than 5 sec but not ...
- Jul 23, 2019Ok, I found a fix that works. I just did it and all back to normal now. Follow this guide in the link below to upload a firmware file to it when it is bricked.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
LuckyLimo
Jul 23, 2019Guide
dthedeejay wrote:Just did a firmware update using the web interface and extender not working anymore.
Tried holding factory reset button for more than 5 sec but not reseting.
Cannot see Netgear_EXT network.
The following lights are showing on the device: 2 green arrows are flashing, and both 2.4 and 5 GHz icons are solid amber.
Thanks for your help!
I just did the same thing and have the exact same problem. (I think it said version 80 at the end of it.) Anyone else? Netgear, is there a fix?
- DisgruntledGoatJul 23, 2019Aspirant
The same thing happened to me.
I've also tried connecting to the unit's IP directly via ethernet with no success.
The update appears to have bricked the unit.
- LuckyLimoJul 23, 2019GuideOk, I found a fix that works. I just did it and all back to normal now. Follow this guide in the link below to upload a firmware file to it when it is bricked.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client- LuckyLimoJul 23, 2019GuideFyi... After I set the extender up again it asked me to update the firmware again. I said yes and this time it went through the update without a hitch and seems to be working fine.
