dthedeejay
Jul 23, 2019Aspirant
WiFi Extender EX7000 - Failed Update
Just did a firmware update using the web interface and extender not working anymore. Cannot connect to extender with http://mywifiext Tried holding factory reset button for more than 5 sec but not ...
- Jul 23, 2019Ok, I found a fix that works. I just did it and all back to normal now. Follow this guide in the link below to upload a firmware file to it when it is bricked.
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
LuckyLimo
Jul 26, 2019Guide
Ok, I am not sure about the .250 one but I know that .1 definitely worked on mine as the default IP. If the TFTP software is not showing any progress than it is definitely not communicating with the extender. What IP and subnet mask did you set statically on your computers network card when you were trying to TFTP into the extender?
DisgruntledGoat
Jul 26, 2019Aspirant
LuckyLimo wrote:Ok, I am not sure about the .250 one but I know that .1 definitely worked on mine as the default IP. If the TFTP software is not showing any progress than it is definitely not communicating with the extender. What IP and subnet mask did you set statically on your computers network card when you were trying to TFTP into the extender?
That was my suspicion as well, though I'd never used TFTP prior to my attempts - so I appreciate the confirmation there. Thank you.
I used the settings included in the KB article:
- IP address => 192.168.1.10
- Subnet mask => 255.255.255.0
- Default Gateway => 192.168.1.1
Windows 10's control panel only allowed me to specify the "subnet prefix length," not the subnet mask, so I followed the instructions in this article to change the IPv4 settings to those listed above before attempting the transfer:
https://www.webnots.com/how-to-change-ip-address-in-windows-pc/
