kah5683
Mar 11, 2024Aspirant
Wifi Extender EX7000 pullout doesn't go back in
I realize this is not a big thing, but it would be nice to put the pullout back in. The pullout has the login, serial number, MAC1, and MAC2, etc. I pulled out at some point, and now it does not sli...
kah5683
Yes, it should slide back it, but unfortunately, it does not. Trying to find a way to get it to slide back in. As I mentioned, I thought maybe I could open the case and see what is blocking it, but I couldn't find a way to do that.
Mar 12, 2024Guru - Experienced User
might just tap it with something. Sometimes the quick hit works better than pushing. I don't have that specific model to test it with
