Bitbat
Jan 28, 2020Aspirant
Wifi extender extremely slow
It works fine in my sisters room giving me a normal connection with it disconnecting and reconnecting every 20 minutes which i suppose is to be expected of a wifi router. The problem is my wifi c...
Bitbat
Feb 10, 2020Aspirant
It's a crappy smartsense router that is provided by my internet, primus. I had a forum on reddit and people said "primus is your problem." Since my download speed is 2.10 and 10.05 with 19 ms response time, usually the 5g disconnects and the 2g cuts it in half to make it even more sh**tter.
I think it's a problem with my internet provider since they chose the slowest speeds possible for me. Cogeco is doing some work in my area and promised fibre optic, we're switching later this year.
Feb 10, 2020Guru - Experienced User
Bitbat wrote:It's a crappy smartsense router that is provided by my internet, primus. I had a forum on reddit and people said "primus is your problem." Since my download speed is 2.10 and 10.05 with 19 ms response time, usually the 5g disconnects and the 2g cuts it in half to make it even more sh**tter.
ouch, those are some bad speeds.
What speed to you get hardwired into your router?
If you're hardwired speeds are decent, the EX6200 has AP mode and might have better wireless capabilities than your current router. You could run it in ap mode with it hardwired in and potentially get better coverage/signal
- BitbatMar 08, 2020Aspirant
I can't hardwire my laptop in since i don't have an internet connection. Ping usually goes to 80ms in arsenal and then 500 if i'm somewhere farther in the house. I also notice the extender getting very hot.
