bratdawg423
Jan 21, 2022Star
WiFi Extender for metal building.
I currently have an EX2700 Extender in a metal shed (My Man Cave!), and needless to say I don't get the best signal (maybe 2 or 3mbs) from my Nighthawk R6700v3 in my house about 50 feet away. I can g...
Jan 21, 2022Guru - Experienced User
If its only 50ft, run an underground cable from the home to the man cave. The time to bury a cable is worth the investment in speed/stability.
The problem you're having is the metal walls. You could put the EX2700 on the exterior of the shed (in a weather proof enclosure) and run a cable from it, indoors to a seperate access point or extender that supports access point mode.
- bratdawg423Jan 21, 2022Star
Thanks for the reply. Unfortunately there's too much concrete (patio and a large slab the shed is on) to run a cable underground. Since the ex2700 is old, I was hoping to just replace that and use a weatherproof antenna which I have found. But I can't seem to find an extender that has a removable antenna.
Steve
- plemansJan 21, 2022Guru - Experienced UserEven if you find one that you can put an external antenna on to be external to the building, that antenna still isn't going to penetrate the metal to broadcast inside the building
Thanks, but I have found outdoor antennas that have a cable with the connector. I can run that into the shed, but I need the removable antenna on the extender to be able to connect it.
Steve
