shadow5837
Apr 28, 2020Aspirant
Wifi Extender in the Access Point mode
I am using the Netgear Wifi extender model EX6150 v2 with the side switch in the Access Point position, connected to my router with an ethernet cat 6 cable. This is extending my wifi signal to my n...
Apr 28, 2020Guru - Experienced User
It just means that you need to log into the extender and setup its wireless security.
you can find the manual with instructions on that here:
shadow5837
Thanks, I'll give that a try.
