bhoot960's avatar
bhoot960
Follower
Jun 21, 2023
Wifi extender is found but say’s incorrect password when trying to connect
The model is a net gear ex2700 and I’m trying to connect it to my Xbox but it just says password incorrect and it has range to the wifi router
1 Reply
  • plemans's avatar
    Did you set it up using the push button WPS option?
    If so, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
