jd006814
Nov 17, 2025Aspirant
Wifi Extender Issues - EX7700
Hello, I have been running a Negear Nighthawk router (Tri Band Ax8 - RAX70) with the Router Firmware Version V1.0.19.172 without any issues. I purchased a Netgear Wifi extender EX7700 to expand th...
Nov 17, 2025Guru - Experienced User
What static IP address is assigned and placed on the EX extender?
What happens if you disable SPC on the NH app and check for device operation and IP addressing?
