jd006814
Nov 17, 2025Aspirant
Wifi Extender Issues - EX7700
Hello, I have been running a Negear Nighthawk router (Tri Band Ax8 - RAX70) with the Router Firmware Version V1.0.19.172 without any issues. I purchased a Netgear Wifi extender EX7700 to expand th...
jd006814
Nov 18, 2025Aspirant
Ok so I can confirm that the static IP is outside the DHCP range on the router. DHCP range ends at 192.168.1.230 and Extender is set with 192.168.1.241
When a device connects to the extender it sometimes appears to get a duplicate IP to another device and also the device is registered as DEV. I will get some screenshots and post. Should I try a factory reset on the Extender and start again ?
