jd006814
Nov 17, 2025Aspirant
Wifi Extender Issues - EX7700
Hello, I have been running a Negear Nighthawk router (Tri Band Ax8 - RAX70) with the Router Firmware Version V1.0.19.172 without any issues. I purchased a Netgear Wifi extender EX7700 to expand th...
jd006814
Nov 18, 2025Aspirant
Ok so I can confirm that the static IP is outside the DHCP range on the router. DHCP range ends at 192.168.1.230 and Extender is set with 192.168.1.241
When a device connects to the extender it sometimes appears to get a duplicate IP to another device and also the device is registered as DEV. I will get some screenshots and post. Should I try a factory reset on the Extender and start again ?
Nov 18, 2025Guru - Experienced User
Now for devices that are connected with the Extender, try setting up some IP address reservations ON the router for those devices connecting at the extender. Mainly devices that you are attempting to control with SPC.
jd006814 wrote:Ok so I can confirm that the static IP is outside the DHCP range on the router. DHCP range ends at 192.168.1.230 and Extender is set with 192.168.1.241
