GForceRTX2090Ti
May 06, 2020Tutor
WiFi extender keeps dropping connection, and it's driving me insane.
Seriously, this thing just decides to drop everything at the most random times and lose all connection. I've tried every possible solution to try and fix this but nothing's worked. My firmware is up ...
May 07, 2020Guru - Experienced User
1. What router are you connecting to?
2. What firmware is on it? "the latest" changes and sometimes isn't.
3. What fixes have you tried? Saying you've tried everything tells us nothing because "everything" means different things to people.
4. so the extender is running in AP (access point) mode and is hardwired to the router via powerline?
5. You realize that powerline isn't always a solid connection? Its sensitive to interference from *surge protectors*, arc fault circuits, gfci outlets, high draw appliances, powerly made appliances, even bad cell phone charges can inject intereference in the powerline.
Might be a good idea to test the extender without the powerline setup to see if its truly an extender issue and not a powerline issue.
GForceRTX2090Ti
May 07, 2020Tutor
1. It's hooked up directly to the wall, which sends it down to the ac powerline adapter down on the bottom level. That goes from there straight to the router via ethernet.
2. Firmware is fully up to date and running the latest software.
3. I've tried factory resets, messing with settings in the ethernet properties, power cycles, etc., and so far, out of all the things that I have attempted to do to fix it nothing has solved it. It still happens.
4. I had it like that and attempted to set it up, but after that it didn't work very well at all. I've since switched it out of AP and back to extender to fix any issues that exist with it. Still nothing, AFAIK.
5. Powerline by itself with both adapters works fine, albeit very slow. The extender works much faster as an ethernet connection with one ac adapter, however I'm experiencing the drops I explained beforehand.
- plemansMay 07, 2020Guru - Experienced User
Firmware on the extender?
Have you tried it in AP mode directly connect to the router with a 6ft cable?
- GForceRTX2090TiMay 07, 2020Tutor
I'm connecting to a comcast router.
Firmware is V1.0.1.86.
I have tried the extender directly connected to the router and even after it started up it still didn't recognize that it was an ethernet connection and it didn't work properly.
GForceRTX2090Ti wrote:I'm connecting to a comcast router.
did you have the switch in Access point mode when you did it this route?
And it didn't work directly connected but it did through powerline?
I'm curious how its working in access point mode through powerline when it didn't directly connected?
