Mathias1976
Sep 05, 2023Aspirant
WIFI Extender needed
Looking to add a WIFI extender to my router. I have it located in the middle of my house and need to extend the range about ten feet to the edge of my garage. i bought a the NETGEAR WIFI AC1200 exten...
Mathias1976
Sep 11, 2023Aspirant
the Nighthawk app says that is is not compatible with the extender i had purchased.
I just need to know which one is compatible with my Nighthawk x4s ac2600 WIFI router.
i have read a couple of other community conversations and don't want to get the wrong one.
schumaku
Sep 12, 2023Guru - Experienced User
Be a little bit more informative which Netgear Extender - the model is certainly on the product label - should not be compatible with the Nighthawk App.
This would be an example of product designation we can work with. Now back to this unknown AC1200 Extender. Note: Apps are not the center of the universe. Every Netgear extender can be installed using "Connect with WPS " or "Connect with the NETGEAR Installation Assistant" - no fancy app required.
Head to https://www.netgear.com/support/ - type in the model number or the product designation and you get access to the Product Data Sheet, the Installation Guide, and last but not lest the User Manual.
