KeKyKo's avatar
KeKyKo
Wifi Extender Netgear Nighthawk X4 AC2200 ‎EX7300v2 lost ethernet connections (LAN)
Hello.  My WIFI Extender ‎Netgear Nighthawk X4 AC2200 EX7300v2-100NAS has lost LAN connection.  WIFI is working great both 2.4 & 5 but the ethernet connection is not working.  In the router settings under connected devices it shows all my wired connections but all the devices say "no internet connection".  Has/is this happening to anyone else?  Did you manage to fix it?  Thanks for any ideas.
  • You can just mark it solved and that'll take care of it.
    Glad you got it fixed.
  •  I DONT KNOW HOW TO DELET A POST.  SORRY.  THIS HAS BEEN SOLVED.  IT WAS A BAD HUB 😞
    • plemans's avatar
