jpk40's avatar
jpk40
Follower
Jun 09, 2025
wifi extender no connection
I have had a wifi extender model ex2800 for about 2 years but have only used it about 5 months each year. the other day I lost the connection to it and cannot get it to work no matter what steps I have taken. the power, device and wps lights are lite green but the router one is blank. any suggestion would help
1 Reply
  • plemans's avatar
    IF its not connecting to the router, you'd want to factory reset and reinstall it using the installation assistant
