fakayun
Apr 13, 2018Follower
WiFi extender not working by hub 5
Ex3110 is the exact model I don't know if I've done something wrong I must've because this won't work with my bt hub 5 it happened after I did the online setup I went through everything i connected t...
DarrenM
Apr 17, 2018Sr. NETGEAR Moderator
Hello Fakayum
To try the setup again you will need to hold the reset button on the extender for 10 + seconds this will factory reset the extender then you will be able to try the setup again.
DarrenM
