JIllarramendi
Jul 29, 2023Follower
Wifi extender not working
Hello, I'm having an issue were I follow all the steps provided by the manual and when I'm connected to the extender in the set up stage, it doesn't have internet yet so the netgear set up page won't ...
Jul 29, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
