monkk
Nov 03, 2024Aspirant
Wifi Extender Not Working
I have a Netgear AC1200 Model Wifi Extender that I’m trying to connect to. The thing is is I have used it before, last year with a different wifi than I have now. It worked perfectly fine and connect...
Nov 03, 2024Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
